Conductor Sizing and Voltage Drop
JBZE
I am sizing conductors for a Freeway Lighting System in CA.
I have 25 - 310 watt lights on a 120/240 volt 1 phase 3 wire system. (lights are run on 240 volts).
My question is this: Am I allowed to downsize the conductors as the circuit gets farther away from the service point and the load (current is smaller).
I calculate about a 5% voltage drop with a #1/0 wire for part of the system. Do I have to use the #1/0 wire through the entire circuit or can I down size the conductor as the load drops farther from the service point. It would seem overkill to use say a #1/0 between the 24th and 25th lights on the circuit.
Any advise would be helpful.
Odd system for "freeway" lighting.
After your initial VD calc. you can break these down into groups of 4 or 5 fixtures and do calcs on each group. EE's don't normally do this. Your job is to do the calc for the circuit as a whole.
Let me ask you this. If I ran #10 between the first and second fixture, then ran 1/0 to the other 23, would an electron know the difference?
As you reduce your conductor, the VD will increase from your original calculations. You will need to keep a close eye on that.
Of course don't reduce your conductor below the overcurrent protection for the circuit.
