I was asked to relocate an existing 75 HP air compressor. The nameplate info on the compressor control panel label stated: FLA 96 amps @ 480V 3ph. 3W. I've always sized the conductors feeding a piece of equipment at 125% of the stated FLA. To my surprise the previous installer had fed the compressor with #3 THHN cu, 100 amp rated wire, not the #1 THHN cu which covered the derating factor of 120 amps. Simple question, but I've run into disagreement about what the equipment nameplate includes/ doesn't from manufacturers and inspectors alike. I'd like to get this cleared up if possible.
