I have a contractor installing 8-parallel 500 MCM runs to a 3000 Amp switch gear. The run is only about 40 feet long but the way they put their conduits in there are some ungrounded conductor that are 4' shorter than others of the same phase. My question is in section 310.4(B)(1) it says they shall be the same length, what does that mean? I have worked as an electrician for years and have had foreman that laid the conductors out on the ground and cut them to the exact length needed and i have had foreman that just pulled them in and terminated them so they looked good. what is the acceptable industury tolerance? In this case referenced the difference in ungrounded conductors on the same phase is about 10%.
