The NEC tells us that we must leave 6 inches of conductors out of a box to make connection to an outlet or switch.  When you have two romex cables into an outlet box you must connect the two grounds together and leave enough ground wire to connect to the outlet or switch.  What the code require you to do with the two ground wires in the box???  Is 6 inches of both ground wires required????
