richwaskowitz
- Shelby Twp. MI, near Detroit
I know about 300.3(C)1, but I am not sure if this applies to my question. We have some SEW Eurodrive motors coming in now with microswitches built in to the brake mechanism which monitor the status of the brakes. A cord from this switch enters the SEW motor's terminal box and two terminals are provided there, right next to the 480 volt motor power terminals for utilizing this switch in the control circuit. The question is, can this article (300.3) be cited to require that the field wiring entering this box to pick up the control circuit which will monitor this switch to have 600 volt rated insulation? Does a motor terminal box fall under "equipment wiring enclosure"? I am trying to argue that the control circuit wiring in the motor terminal box needs to be rated 600 volts also but the customer wants me to show them why.
