Ok Celtic, but the way I was taught, we didn't have any idea what angle was used. We just bent it until it looked good, then we would measure and mark the conduit. Finally, we would make the second bend until the conduit looked like it was going straight again.
No offense...but you weren't taught anything. Someone showed their convoluted way of making pretzels out of pipe.
You don't need to know what size angle to use - unless dealing with multiple runs or trying to match existing runs. What you need to know is how much bend is in the run between pull points.
"Guessing" is not being taught.
Also, I can't figure out what good it is to mark the distance from the center of the bends. When you put the conduit in the bender, the shoe is the start of the bend. The center of the bend would be back some distance depending on the radius of the bend and the angle of the bend.
Let's look at this from bending a 90.
Say you have piece of 1" EMT, the shoe calls for an 8" take-up.
You measure from the end of your last pipe to the wall/obstacle and get 35.75". Marking and bending the pipe at 35.75" will give you a pipe that is 8" too long. What you do is deduct the take-up from that 35.75" mark, So the actual bend mark is now 27.75".
Now imagine you have a rack of 1" pipe that has a set before that 90. All the other pipe looks picture perfect.
Are YOU going to be the one that makes the whole rack look like something Fido left behind?
Of course not.
You get out your protractor and lay it on the set. ...all of a sudden that set that you thought was 30 shows it as a 22.5..
So now you know the angle (22.5 w/multiplier of 2.61).
You can easily measure the height of the set against parts of the builing or by other means (laying a pipe across the rack to establish one side as "level") Now you see the set is actually 13.375".
2.61 x 15.375 = 34.90875...just shy of 35".
Now you know the height of set (13.375") and the distance between bends (just shy of 35")...but where do you put the first mark???/
If you could find the center of the existing bends (which is quite easy), you could put your mark on the pipe, using a mark on the bender that shows "center"....Greenlee benders have a "star" that indicates center:
See it there...just below where the handle would be inserted?
A bender that doesn't have a center mark can be easily found using some scrap, a sharpie, and a ruler.
It's these little things that seperate a journeyman from a mechanic (mechanics work on cars).
I also remember frequently "taking a little out of a offset" by smacking the conduit on the concrete floor
Try that with some 4" RGC
My bends usually had some pretty bad dogs, I would usually have to find a good spot between some columns and braces to pry the conduit aginst.
That will take some practice using the proper methods...you just need to be taught the right way (as opposed to any which way, just make it fit).
The link I provided above has a wealth of information.
When you get to break out some serious brain cells on a rack of pipe all different sizes but all RGC you will see there really is a method to the madness. Then when you are confronted with a rack of 3/4" EMT, you'll laugh at it - especially when you overbend/kink the first bend
Bending pipe is a form of art. In this day and age of "faster and cheaper" and "slam-jam and scram", the art is on it's way to oblivian.
When one of the guys from Chicago reads this thread, I am sure he will have some "tips" (Chicago is an anti-rope-slinging town)
EDIT: Who busted the "quotes"?
