winnie
- Springfield, MA, USA
- Electric motor research
John,
It would appear that you've bought a couple of the most insidious myths about electricity. These are things that sound reasonable, that we've been taught over the years as part of 'common sense' or 'conventional wisdom', and which are outright _wrong_. This is not to cast any sort of aspersions on you; we've all been there, and had to unlearn these things.
1) Electricity follows the path of least resistance. This statement is strictly true to the point of being misleading. The reality is that electricity follows _all_ paths available to it, in inverse proportion to the resistance. This includes the 'path of least resistance', but it also includes the high resistance parallel path.
2) Electricity tries to get to ground, or a ground rod is a safe place for electrons to go. The reality is that electric current always flows in a closed circuit path, and always 'trying' to find a path back to the source. The 'source' is usually a transformer. Soil is entirely irrelevant to this truth. For reasons of safety, we _bond_ all non-current-carrying conductive material back to the source, and electrically connect it to one of the source terminals. The Earth is simply another chunk of conductive material that we need to bond.
In the event of a short circuit at the range (I presume hot to frame, 4 wire circuit), current will flow from the transformer along one of the 'hot' conductors, through the main breaker, down the bus bars to the branch circuit breaker, through the branch circuit hot to the range frame to the branch circuit EGC, back to the panel, through the 'main bond', and then through the grounded conductor back to the transformer. Additionally, since there is a grounding electrode at the transformer, and grounding electrodes at the panel, some portion of the current will follow the parallel path through all of your grounding electrodes, into the Earth, and back to the transformer. But the bulk of the current will follow the copper wire path. The only breakers that could trip in this case are the ones in the path of the current, and the grounding electrodes at the outbuilding are irrelevant to this.
-Jon
-Jon
