Here is one for the engineers is there any reason one can't run a conduit in the bottom of a footing?
I usually run it under the gravel then stub it up, or cross a footing.
Its not on the engineers drawings its residential single single story construction.As long as the engineer's drawings show it that way
presumably the engineer that made the drawings considered this.The footing design needs to be evaluated to make sure it can still support the building with the conduit taking the place of part of the concrete.
Its not an engineered foundation its a residential code 'prescriptive' design.presumably the engineer that made the drawings considered this.
Presumably there were than a bunch of engineers who reviewed it and found it acceptable.Its not an engineered foundation its a residential code 'prescriptive' design.
Its not a big deal I am trying to keep the feeder conduit considered 'outside the building'
I think the builder draws his own plans, no sign of a architect or engineerPresumably there were than a bunch of engineers who reviewed it and found it acceptable.
But I doubt that the prescriptive design accounted for the conduit in the footing, so it needs to be evaluated to a performance standard.Its not an engineered foundation its a residential code 'prescriptive' design.
I definitely wouldn’t approve a footing like that.(as if someone would ask my opinion..)Here is one for the engineers is there any reason one can't run a conduit in the bottom of a footing?
PVC raceway would solve that issue.Conduit probly needs to wrapped with plumbing foam tape
Even though it is residential, when you're talking about the footing, I would ask for a structural engineers opinion at the least. If for no other reason than to save your ass instead of saying "it was on the drawing so I did it."I think the builder draws his own plans, no sign of a architect or engineer
Its a change of panel location and they dont want to dig the gravel up and mess with the rebar.
