We are about to start a job doing some line voltage in some exterior landscape CMU walls (stucco faced) and I am debating if this is a wet , dry , or damp location. The homeowner wants flush receptacles to the finish walls so we are going to run conduit stubs up before the landscape block masonry guys set their wall and footings. What I keep questioning is if a weatherproof box is required even if the box will be encased in mortar in the wall. Anyone have an opinion on this? Of course we will be using weatherproof covers but I cannot see how to get the flush detail correct with a full weatherproof enclosure. Corrosion of the aluminum would also be a concern if we had to go with a weatheproof box. 4 square deeps with mud rings or masonry boxes would sure make life easier.
