In a vertical conduit run, where the conduit needs to turn 90 degrees through a concrete wall into a Class1 Div 2 atmosphere, is it practicle to install a vertical seal fitting directly below an explosion proof LB to keep the conduit run as close to the wall as possible? A horizontal seal would leave the conduit about 6" away from the wall due to the size of the body, in this case we are running 1 1/4" conduit.
