brad richmond
New member
- newport beach, ca
I have a project for a client who is running (12) 1000 HID fixture in his current grow room, the panel is approx. 50ft. away from his remote ballasts. The ballasts are 240 volt and
use 4.5 amps. Panel is 120/208 volt, 3 PH, there is a 3/4" conduit with (8) # 12 conductors feeding (4) quad receptacles (120 volt devices) wired with 208 single phase. when I amp prop
the breakers they are about 17-19 amps, the breakers are slightly warm, however the branch conduit is almost to hot to touch. Is this a derating issue? the devices are not hot at all.
