Alwayslearningelec
- NJ
- Estimator
Have new construction and many conduits going to electrical closets with block walls. Whihc is more often the case?
1. Would there be no need for a sleeve as conduits should be run before brickey gets all the block up? Just run your conduit no need to do anything in regard to block wall.
2. block is already installed "blocking" you and you need to penetrate. That would not make sense.
3. Brickey installs block before you get there but leaves a window for your conduits?
