I've never used smurf, only pvc. So what's the skinny on this stuff? Are you guys using it only on decks or slab on grade too? How's it pull through? Are you using it on big feeders or just little stuff?
When do you pick smurf over pvc?
decks mostly... i've used it on grade, but it's a post tension slab slam dunk
it requires under half the pulling force.. the wire just glides on the ribs.
you can also blow jet line thru it a lot farther than schedule 40
i don't run it above 1", but it's fast to do.
they make a nice lightweight cutter for it, but you can also use a
razor knife, and score in one of the ribs half way around, and just snap it.
they have snap couplings, FA and MA connectors, but they are a bit pricy,
so i just glue it with regular pvc couplings.. water tighter that way, and cheaper
it's crazy nuts fast to run with snap couplings tho, and they don't come apart.
you have a belt and a nail bag full of couplings, and a snipper tool, and you just
scream... use cheap tye raps for strapping.
that 1000' an hour day, i was just getting lifts dropped, cutting them open and
pushing everything towards the main switch gear room, on the 4th floor.... the
foreman was laying out the deck, the muppet was wiring up yard ells or red dots,
so it was just put the stuff in as fast as you could.... but it came out to a 100'
bundle in the deck every five minutes.... there were spots there was more smurf
than concrete.
and best of all, it's blue. how can you not like blue conduit?
