Hello, I desire to power (4) 300W LED COBs simultaneously via a single 120v AC plug. Each COB has their own 300W driver. The driver is AC input and DC output. It is a constant current driver.
Here's the spec sheet of the driver. I assume I would be using the H-AB, which provides a DC voltage range of 29-58v, and 3-in-1 dimming which is another part of this. https://www.meanwell-web.com/content/files/pdfs/productPdfs/MW/HBGC-300/HBGC-300-H-AB.pdf
Here's the spec sheet of the COB: https://download.luminus.com/datasheets/Luminus_CVM-GEN4_Datasheet.pdf
Here's a crude drawing.
1) What are your thoughts on compatibility between the LED COB and LED Driver? Seems like a good match to me, I just don't want any chance of frying the LED so would like some other eyes to confirm. Similarly, are there any precautions or additions one should make to prevent overload in any way?
2) Please let me know your thoughts on the wiring? Some might question a 10amp draw like this, and the addition of a plug, but it is very normal for my specific application.
3) I plan on implementing dimming, but need to ensure flicker-free for camera application up to 2,000FPS. I imagine I can go the PWM dimming route via the driver, but will have to test it. Other than just a potentiometer/analog, what is an efficient way to dim the LEDs and ensure flicker-free application? I understand if this means adding an additional component vs utilizing the driver's internal dimming functionalities.
Thank you very much!
