confused
We have not had clarification from the OP as to whether he is referring to a ring for flush mounting a receptacle or a cover for cover mounting a receptacle. It will make a difference in what code section applies.
That would be nice but it probably won't matter much.
These covers attach the receptacle through the same holes that would attach it to a dry wall ring, only more solid with a nut and bolt.
This cover attaches to the box no different than a drywall ring.
I don't see where this would require a ground wire.
This was discussed at least once before back in 2004 ( I ran into that discussion by accident).
2008 nec 250.146(A) has a "new" shaded section at the end that I think allows these covers to be used with out a jumper wire.
And the OP said 2005 NEC.
An 8/32 holding a "mud ring" to a steel box isn't as good as a 6/32 holding a device to a box?
Isn't the code great?
It might come loose, so too the 6/32 or the building might fall down.
Where is the definition of "cover mounted"?
...Where is the definition of "cover mounted"?
In a dictionary.. first look up "cover" and then look up "mount(ed)"
ARTICLE 100 Definitions
Scope. This article contains only those definitions essential to the proper application of this Code. It is not intended to include commonly defined general terms or commonly defined technical terms from related codes and standards. In general, only those terms that are used in two or more articles are defined in Article 100. Other definitions are included in the article in which they are used but may be referenced in Article 100.
