- Windsor, CO NEC: 2017
- Hospital Master Electrician
I had an emergency panel change over the weekend. FPE panel, FPE service (to be changed shortly.)
The old panel developed some sort of issue (that I never fully understood), basically it developed an internal short, blew a hole in the bussing and knocked out the utility transformer fuse.
As I was hooking up the old circuits in the new panel, I tested for continuity and found a home run that had 4 ohms. I did a little math and concluded that the circuit would be pulling 27A when I energized it. When I fired it up, it was only pulling 4A.
What gives?
What gives?
