I have received conflicting advice on a spa install I was hoping to get input. I have an existing 220 outlet previously used for a welder. It is a 3 Wire hook up (appears #6 aluminum). My intent was to utilize that run for a spa hook up.
One electrician has said I need to run a whole new 4 wire set up from main panel. Another has said we can utilize the existing wiring by adding a sub panel and if we add a separate ground wire affixed to a stand alone ground stake.
The main panel is quite a distance ....So the cost to DO A full 4 wire replacement from there makes the other option (adding a ground stake) pretty attractive. Both claim option they propose is safe.....But the one proposing the full 4 wire run claims the ground stake option is dangerous.
Is he trying to upsell me or is there really a danger?
Really appreciate any feedback.
Thanks
Charles
Thanks
Charles
