Alexei
- Massachusetts
- Engineer
I am in Mass; NEC 2020
I have a metal box with ground wires
- 3 x 10 AWG
- 2 x 14 AWG
I understand I need to connect all 5 cables together, and to the box
Usually I connect ground wire using Greenie Grounding Wire Connectors 92 and leave one cable longer to go through connector hole and connect to the box.
I can not find any connection which is rated for the wire combination I have.
I am contemplating a crimp connector, e.g.
http://www.nsiindustries.com/catalog/nsiproducts/connectors/easy-twist/sb1808
https://www.gardnerbender.com/en/products/Connections/Crimp-On-Connectors
but I do not know if it is listed for such application, or if it even would fit.
Another options is to install a ground bus, but can not find anything listed either.
Could you please advice a NEC compliant option to do it.
- 3 x 10 AWG
- 2 x 14 AWG
