I have run into an interesting situation. I am helping re-design an office building into a dormitory. This requires about a 3,000-amp switchboard at 120/208, 3 phase. We are stepping down from a 277/480 volt system. Instead of using one large dry-type transformer, we were looking at using three smaller dry-type transformers. Has anyone ever seen this done? What does the code say about it? How would you connect them? On the secondary side I figured you could just take the feeder from each transformer to the switch board. But I might be wrong about that. I was thinking that each transformer should have it's own feeder on the primary side. Any ideas or comments would be appreciated.
