speedypetey
- Hudson Valley, NY
Re: connector backwards
I usually drill a 4" hole saw in a 32"x48" piece of 3/4"CDX at my connector. This is plenty for the connector to fit in even with it's long screws.
Mainly though I use a 2" pvc nipple between back to back enclosures. Mount one, measure for the nipple, mount the other.
[ December 14, 2003, 08:47 PM: Message edited by: speedypetey ]
So you're not mounting your panel boards on a piece of plywood?Originally posted by binney:
Member # 12900
Why don't you just put the connector on the cable before you mount the panel. Then mount the panel and run the LN and bushing on.
2 reasons.
1. When running the cable through a solid concrete wall it's easier to face the locknut and bushing to the back,then set screws on the connector. The LN and bushing fit in the hole we drill for the SE cable. If you put the set screws to the back you need to get the BFH and the chisel out to make room for the screws. (if your solution to that problem is drill a bigger hole, I've found out the hard way people have a hard time with you drilling a hole any bigger than absolutely necessary in there new poured walls.)
2. There's more room for error. Nothing makes me more mad, than hanging the panel up, and finding out I can't get the LN and bushing on. That's why a lot a guys just float the wire in, and don't tighten the set screws.
If it's quicker, easier and safe why not do it?
