- Placerville, CA, USA
- Retired PV System Designer
Independent of the actual armature motion, the magnetic circuit is tighter once the pole faces are in contact. That means higher inductance and therefore lower current once the contactor has finished closing.Right. The inrush is not because the coil is an inductor, the inrush is a result the moving core (in the case of a solenoid) or armature (in the case of a contactor) and the time it takes to complete its motion, lowering the inductance in the circuit.
This does not apply to DC except for the final time constant.
mobile
