i ran across an old GE 200 line motor controller that controls a well pump through pressure switches that has some rust where the armature contacts. I cleaned it with an wire brush hoping the chatter would stop, but no luck. Is it better to replace the compete contactor or did I not clean it enough? There is adequate voltage, and the chattering may have been going on a long time...could that have burnt out the coil that will continue to cause it to chatter? I was wondering if I should just replace the whole contactor or replace the 240 volt coil. Is there an easy troubleshooting chart for motors and contactors someone could refer to me please? Thanks again!
