Jerramundi
- Chicago
- Licensed Residential Electrician
I thought DC wave form looked more like the McDonald's arches than it did a straight line (i.e. constant). That unless you have a device that specifically regulates itself to output a constant voltage. Aside from that one instance, wouldn't that mean DC voltage still has a 0V point in the cycle and thus would be equally as likely to extinguish that arc?Not necessarily is the arc automatically maintained when switching DC current, the deal is that the arc is easier to extinguish when switching an AC circuit because voltage crosses zero every half cycle. DC the voltage remains constant and contines to feed the arc until the gap between contacts becomes large enough the voltage can no longer maintain that arc. The higher the DC voltage the more gap is needed to extinguish the arc.
