- Placerville, CA, USA
- Retired PV System Designer
So each upper container rests only on the stack below it?
And the bottom one rests on asphalt or dry concrete?
That certainly could have enough resistance to ground to avoid tripping breaker, except for the fact that other containers in the same stack should have good EGCs.
Sounds like OSHA would like to see a portable tester for the cord each time a container is plugged in.
