RustyShackleford
- NC
- electrical engineer
How does one compute the continuous load (which must be supported at 125%) for a heat pump with electrical resistance heat strips (that can operate simultaneously) ?
The heat strips are simple, assume they're fully on (if there are multiple segments used for staging, assume they are all energized).
But what about the heat pump ? Manufacturers quote a LOT of numbers. I'm thinking you don't need to consider numbers as high as the MCA or RLA as "continuous". There are various performance tables, which quote wattage for a plethora of indoor and outdoor temperatures; so use the highest such number in the tables ?
