Glenn Becnel
I would appreciated some help with an issue I recently observed. An A/C contractor on a new construction project apparently installed a conduit into the wrong piece of equipment (A/C Chiller Unit control panel). The problem was conpounded when he installed another conduit from the same control panel to the correct equipment. He has pulled the wire (low voltage) through the control panel (contains 480V). Wires in these two conduits are not terminated in the control panel. He is using the panel as a pass-through. Where can I find this violation in the NEC?
Thanks in advance for your help.
