Mikekc44
- New Castle, In
I have a small pumping system that needs to be turned on or off by a plc base Scada system located in a different area of the plant. I also need to signal the main control system if my unit goes into a fault condition. I currently am thinking the best option is to use 24vdc control voltage for sending and receiving start stop or alarm signals. Using that option the main control panel would use a 24vdc relay and run two conductors from my panel to energize the relay if my system goes into a fault condition. When that relay energizes the main control system knows to shut down related pumping equp. Also we would have two conductors coming from the main control that would carry a 24vdc+ and 24vdc- currten to fire a relay in my panel to tell the unit to start or stop. Is there a better option that I could use. I am thanking you in advance for your input.
