Is a white wire with tracer used as a control wire acceptable or not?
C CRANK New member Jan 18, 2011 #1 Is a white wire with tracer used as a control wire acceptable or not?
Little Bill Moderator Staff member Location Tennessee NEC:2017 Occupation Semi-Retired Electrician Jan 18, 2011 #2 CRANK said: Is a white wire with tracer used as a control wire acceptable or not? Click to expand... Most of the controls I work with use white w/tracers as a common or sometimes the neutral on a coil. I must add most of the machines are European.
mbeatty Senior Member Location Illinois Jan 25, 2011 #3 Little Bill said: Most of the controls I work with use white w/tracers as a common or sometimes the neutral on a coil. I must add most of the machines are European. Click to expand... I agree with Bill. We only use white or white with a tracer for common in our control boxes.
