JFletcher
- Williamsburg, VA
I have an upcoming job where the HO is converting an existing dining room to a bedroom. I have a few questions re: the electrical on this remodel.
#1: I know that it will require AFCI for all outlets. Since the panel is an FPE, can I use an AFCI as first receptacle then wire everything (lights and SA too ) from that point, or will I have to bid in a panel change? The existing receptacles will be abandoned and a new 20A circuit run installed for the room, and dedicated circuits for window AC and baseboard heaters.
#2: Re: #1, I looked but cannot find where code would require lights and receptacles on separate circuits (2012 IRC, based mostly on 2011 NEC).
#3: Does the closet require a light?
#4: I've found baseboard heaters with wireless thermostats; any caveat or tips with those?
eta: the existing switch for the overhead light/fan is on a switch loop, no neutral. Can this stay or does new wiring have to be pulled in? and all of the existing wire is 2 wire cloth NM.
