chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
I saw I bunch of these in Chicago. New to me, but looks like a real time saver. Anyone install one of these?
I'm trying to igure out what's with the white wires running halfway down the pole in conduit, then swinging back up to the weatherhead. :-?
I like the 90's at the bottom, wonder how thick the wall is, and what the inside pipe runs looks like?
Isn't this all communications stuff?
Kind of resembles a bird house...with plumbing.
Even if this is a power service, the NEC does not require an outside disconnect.Shouldn't there be a disconnecting means somewhere accessable to the fire department in case they need to turn off power to the building?
Isn't this all communications stuff? Look how low everything is and how high the triplex is on the pole. :smile:
What kind of conduit is that? Look close at the couplings.
