Coolest way to do this??
jjhoward
Northern NJ
Owner TJ Electric
What is the coolest way to get wire through all those damn beams when installing old work HHs?
Lving space above the room, finished basement below.
So we usualy cut holes in the ceiling between the beams and then drill holes and pull wires.
Any magic to minimize the ceiling cutting?
Thanks!
Wiremold?
There is really no easy way to do this without cutting holes. You can make one hole and use a long flex bit to drill through several joists, but I don't reccomend this. I was on a job where someone took out a 4/0-4 SER cable doing this.
Yup, been there, not quite done that but we have hit a pipe with those long bits, gone through the floor upstairs and once went through a roof.
We have retired those bits.:)
peter d said:
Wiremold?
ouch! i heard about a guy taking out the service cable a couple of weeks ago while cutting a floor out w/ a 9" sawzall blade.
I have pretty good luck with the flex bits. You do have to use your mind's eye as you drill. The placement tool helps a ton. I generally cut all my circles for the cans first, then look around in each one to scope out my plan. Sometimes there's already holes in the joists you can utilize from other work. Get you one of these: http://www.ridgid.com/Tools/SeeSnake-micro
The trick to the flex bits is to get started straight to begin with. The holes will go "uphill" as you drill in a ceiling, so start low. Wag the bit back and fourth to get an idea of the total height you have available, and start on the low side, as straight as you can. I sometimes drill from both directions, and poke a fish stick in from both ways and hook them in the middle. I put the hook on one, and a loop on the other.
Toss a couple 2-1/2" snap-in bushings up in the ceiling cavity too, for no special reason.
center hole
center hole
I guess you know when you first draw your six inch round hole for the renovation light. Drill or poke a small hole in the center. Make a L shape out of a piece of wire, with the small part of the L about 3 1/2 inch. Insert the small part in the center hole then turn. This way at least you wont hit a beam on your light hole cuts.
I love to see them recessed speakers they make great access.
I have a truckload of them coming straight from Arlington - special delivery. How many do you want?
when i do old work in celings i usually try to find a closet close by to make the hole in the celing in. then i fish from the celing to the basement and over to where they want the switch. you never see any holes when im finished unless you open the closet :)
$200.
You can also use one of these to aim your flex bit:
The flex bit is a good approach but sometimes there is just too many things in the ceiling to use that flex bit.
HWBB lines
Water line
Wiring
Gas lines
Usually there aren't any good clues to let you know these things are there.
I guess that see snake tool could let us know if the bay is clear with only making a small hole.
Yes, we have used that flex bit holding/aiming tool. It does help.
That see snake tool is only $200. Sounds like a winner to me!
My crew has done 56 remod cans in Jan and we do many. MD has all the answers on this we do all that he is talking about it takes time to "know" where things are and might be but you can get good and make a lot of happy customers.
electricalperson said:
sometimes i really enjoy old work. takes skill
What's really fun is pulling off a complicated remodel and not damaging any finished walls/ceilings/floors and know you still did it right.
I have another method I use when the spacing between the recess cans is so far apart, I am not about to try flexibit drilling that far. Most of the 2 story houses I run into are newer, unlike what you guys in the East encounter. The second floor rooms usually have carpet on the floor, and the flooring is mostly plywood. I'll pull up the carpet, take a skill saw set on an inside 45 bevel and set for the thickness of the plywood. I cut a channel out about 3" wide, pull up the piece and save it for re-installation. Once I have drilled out the joist from above I can simply route the wiring, and then screw down the wood piece again. It will sink slightly now due to the thickness of the saw blade, but usually the carpet pad makes this unnoticeable. I don't carry em around with me in my truck regularly, but I have a couple of carpet stretchers. I put the carpet back and bingo bango done.
