Coolest way to do this??
buckofdurham said:
I guess you know when you first draw your six inch round hole for the renovation light. Drill or poke a small hole in the center. Make a L shape out of a piece of wire, with the small part of the L about 3 1/2 inch. Insert the small part in the center hole then turn. This way at least you wont hit a beam on your light hole cuts.
I love to see them recessed speakers they make great access.
I do the same thing with an offset rotary type screwdriver.
macmikeman said:
Do they not spray texture much in your area? Matching sprayed texture is out of my personal league.
Know any one who's league it is in - maybe they need some work.... :wink:
I used to have a rocker/painter/faux finisher follow me around for a while until he had personal issues take his life over.... Other than that it worked well for the both of us.
Flex bits can easily make a small job a big repair IMO. Too bad you can't train rats to do it.....
Typically we only do a rough patch. Finish patch and paint is excluded.
MOST of the time there is other renovation going on and their drywall/paint guy takes care of it. If not we give them the name of someone who will make it pretty again.
Ocaisionally, if it's a small patch I will do my best to finish it.
We have customers tell us they call to have patch work done and everyone wanted from $200 to $275, for a small patch, were in the wrong business.
We're not in the wrong business. We just don't place a high enough value on our services and charge enough. :)
Electricians would go out and do this for an $80 service call or for free in hopes of getting more work in the future.
If every electrician charged $200 for a service call I believe people would pay it just like they pay over $3 a gallon for gas.
Almost everywhere around here the ceilings are "strapped" or "furred". So you can fish across an entire ceiling generally without obstruction.
That's awesome. We hardly ever run into that here. That's usually a framing detail reserved for blueboard jobs, from what I've seen.
