Re: Copper Compact Conductors
Thanks for the info MCW5, but I only need a #3 or larger. Since the bonding is in the meter, and there is fuse protection at the disconnect, this is an Equipment grounding conductor. So it is sized per table 250.122.
I didn't see compact standed copper on Pirelli's website.
I did think about the jambing issue, and with XHHW, I'm at the very bottom of the range. With the very short pull, hopefully, it won't be a problem.
Steve
