U. P. Chuck Electric
Banned
- Lynn, MA.
hillbilly said:Common sense has got to play a part in the equation.
I looked high & low in the NEC & can't find any reference, to any installation, with the mention of common sense.
You have to be kidding me, how is it that no one cares about a listed piece of equipment. Ok to start off if is tested and listed with NO EQUIPMENT GROUND! Now you think you need to add one......wrong......That is not how it was tested and then later approved by the lister. Maybe you should quit giving people so much bad advice. When you chose to ignore a listing you will be responsiblehillbilly said:Since when are you not allowed to ground any exposed metallic parts that are likely to become energized?
My opinion...
If the customer wants that particular light fixture, put it up.
If it needs grounding, ground it.
I may get flamed for saying that, but that's what I would do.
It's only a light fixture, you're not re-wiring the microwave.
410.17 General..."Luminaries and lighting equipment shall be grounded as required in article 250 and Part V of this article".
250.112...Exposed non-current carrying metal parts of the kind of equipment described in 250.112(A) thru (K), and non-current carrying metal parts of equipment and enclosures described in 250.112(L) and (M), shall be grounded regardless of voltage.
250.112(L)...Luminaries (Lighting Fixtures) as provided in part V of Article 410.
I can just see one of my customers when I tell them that I can't install their antique light fixture because it doesn't have a grounding wire and I can't install one because it would void the UL sticker (if it even has one).
They would tell me thank you (maybe) and show me the door.
How would that violate a listing anyway, you're just following a requirement of the electrical code.
Not grounding the fixture has the potential for causing you more trouble than adding a ground if someone gets shocked because you didn't ground it.
I personally would replace any defective conductors and lamp sockets, add a grounding conductor and install the fixture.
Just my opinion, others may vary.
steve
pipemaster said:You have to be kidding me, how is it that no one cares about a listed piece of equipment. Ok to start off if is tested and listed with NO EQUIPMENT GROUND! Now you think you need to add one......wrong......That is not how it was tested and then later approved by the lister. Maybe you should quit giving people so much bad advice. When you chose to ignore a listing you will be responsible
And. . .Hillbilly said:250.112...Exposed non-current carrying metal parts of the kind of equipment described in 250.112(A) thru (K), and non-current carrying metal parts of equipment and enclosures described in 250.112(L) and (M), shall be grounded regardless of voltage.
The rhetoric that pipemaster is espousing is smoke. I think that "clips" has enough of its own "smoke factor" as to apply nicely here.George Stolz said:410.18 Exposed Luminaire (Fixture) Parts
(A) Exposed Conductive Parts Exposed metal parts shall be grounded or insulated from ground and other conducting surfaces or be inaccessible to unqualified personnel. Lamp tie wires, mounting screws, clips, and decorative bands on glass spaced at least 38 mm (1 1/ 2 in.) from lamp terminals shall not be required to be grounded.
