jimthesparks
- Chicago, IL
Does anyone know where cord reels are covered in the code?  I can find it.  Thanks.
			The reason I ask is because the cord reel is rated at 13A 125V but came with double duplex 15A receptacles. I'm thinking that it is fine but it just seems odd.
I guess the way I was looking at it was a 15A recpetacle being fed with a 13A feed.So plug 4 - 3.25 amp max loads in and you are at 13 amps, or any other combination that adds up to 13.
If it were rated 15 or 20 amps and had double duplexes you could still plug in more equipment than it is rated for yet you would not have questioned the rating.
Good point did not think of that.Or maybe the 13 amp rating is a continuous rating??
