foghorn280
- Eugene Oregon
Another application that is becoming more prevalent is in hospitals for patient lifts. The power supply looks like a laptop power supply and the 12 volt leads energize the rail which the actual lift is attached to. The hospitals want these power sources plugged into above ceiling receptacles. The definition of an appliance is just nebulous enough to make the case that the device is an appliance which is the direction from the Electrical Engineering firm I am working with. I have suggested to the US distributor for this product which is European, that a simple transformer such as is used for doorbells would not only satisfy the NEC requirements, but would also be a much cheaper alternative. At any rate you win some battles and you lose some, the engineer's name is on the document OK'ing this installation, not mine.
