mstrlucky74
- NJ
I’m told guys doing standard 2-4” core drills through a 6” thick slab get 3-4 cores out of a bit before it’s toast? True?
Which process? Wet diamond? If so you will get many more than that, I would say at least dozens.
Not sure exactly what you mean? Dry or wet? If so I don't know what process they are using or he is referring to.
Wet diamond is the most common and most efficient. It can be done dry if water cannot be tolerated. There is also carbide bits for rotary hammers, but that is miserable.
So what exactly do you mean by Wet Diamond? That's the brand?
While I know I get more than 10 holes out of a core bit, I add 10% of the cost of a new bit as an expendable for the bid price for a job that requires core holes.
Well field guys are telling me they on get 3-4 cores out of a bit.:huh: I add cost for bit as well.
then your field guys need some training as you will get a lot more that 3 or 4 holes from a bit if you know what you are doing.Well field guys are telling me they on get 3-4 cores out of a bit.:huh: I add cost for bit as well.
Wouldn't you always wet core? Why/when dry core?
BTW, its a wet core that they are saying 3-4 cores per bit.The teeth are steel with diamonds in them, you pump water into the core bit to cool and lube the bit, flushing a slurry of concrete, stone, metal out of the curf cut by the bit. If your men only get 4 holes per, than it is probably dry core or you are coring through lots of rebar.
Either junk bits or not being used correctly.
