- Wisconsin
- PE (Retired) - Power Systems
We are discussing corner-grounded deltas, not high leg (center tapped) deltas.Thank you. I have never personally ran into such a set up in the field. Rarely a high leg delta do I see.
Per the NEC, the grounded conductor is supposed to be white. Old installations tended to ignore this requirement. The NEC allows switched grounded conductors.But I’m curious even in the main/service disconnect can the grounded conductor be ran through the breaker? Or what is a typical installation?
It looks really strange to have a white conductor run to a breaker. My experience has been when following the NEC colors most installations use 2-pole breakers likewise, when following more typical colors 3-pole breakers are common.
