I have been studying the code and watching instructional videos on sizing motor conductors. I know that for continuous duty motors you have to use values from Tables 430.247-430.250 and multiply by 125 percent for conductor sizing (unless the note applies at the bottom of table 430.250). There are some that state under 100 amps use the 60 degree column and 100 amps or over use the 75 degree column. Another video said for motors always use 75 degree column. I took a practice test and even though the question specifically stated 60 degrees the correct answer on the test applied the 75 degree rating. If there is no derating or adjustment factors, can somebody explain to me which column to use and when it is applicable. I am studying for my license and I know the word "Minimum" is used quite often. Thank you in advance!!
