Is this in CA? Is the EE contractually responsible for complying with 'all applicable codes' ? If so you may want to remind them of California title 24 energy code 130.5 (c) Voltage Drop. I looked into something like this in CA over a decade ago and that first appeared in 2013 so its not new.We are working on a project where the electrical engineer is using a Buck Boost Transformer to correct the voltage due to the distance from the electrical panel. We feel that it will not work but unable to prove or disprove that we will have the correct voltage at the receptacle.
The maximum combined voltage drop on both installed feeder and branch conductors to the farthest connected load or outlet can not exceed 5 percent of the NEC article 220 calculated load.
