pjholguin
If you are going this route you need to pay attention to field cuts and threading, these points need to have the PVC coating repaired to close as possible to the original coating and exposed threads and field threads need to be protected from corrosion using approved sealants. FWIW
PJHolguin
PJHolguin
Okay lets suppose that we decide to replace the RMC with PVC coated metal conduit as made by Thomas & Betts. This type of conduit is neither pure metallic or pure PVC. How would you support this conduit? Would you support it at 10 foot intervals as you would with RMC or would you support it in accordance with NEC Table 352.30? The existing conduit system is 3" diameter.
