lgmagone
- Orlando, FL
Hello,
I am contemplating a couple projects for feasibility. The local power company requires me to pay them $125 per idea before they even provide rough order of magnitude cost estimates for new residential service. I'd like to try to get some ballpark numbers to see what we're looking at before deciding if it makes sense to continue fleshing out the ideas.
Can you guestimate the cost of the options below in your area, and if you are comfortable, mention whereabouts you are talking from? I can then scale them to the area that I am looking at. I know that the power company is the one to make the official determination, but I need to decide if I have budget to even make it worth talking to them.
There is a pole pole (newly installed in 2017) on my property. It currently has a line that connects to the overhead main, drops underground, and runs to a neighboring property. There is a padmount transformer on the neighboring property.The options I am considering:
1) Have the utility company install a pole mounted transformer and run overhead secondary line to the desired location.
2) Run an underground line from the neighbor's padmount transformer to the desired location (100 feet). Most likely, he will not allow me to run underground power on his property. (You can read this as he won't, but I suspect this is the amount that the utility would credit me for new service, so this is helpful information.)
3) Have the utility install 50 feet of HV line from the power pole to a padmount transformer location, and then run 100 feet of secondary to the desired location.
The utility states that they provide a credit to offset the cost for new residences in the amount equivalent to 150' of new service, excluding the trenching and conduit costs. I do not know if that credit assumes that I would hook into the nearby padmount transformer or if they would include the cost of a separate padmount transformer for my site as well.
Thank you.
Thank you.
