Craigv
- Boyertown, PA, USA
My irrigation well would probably be small scale. Maybe 35gpm down 300 feet. The well would initially be used for irrigation but could be repurposed for residential usage should I eventually build on the property. Building is just not the plan today.
As you stated you don't want the utility to use your land for power access to the neighbor, let's proceed under the assumption you get your own transformer, and even though HV is cheaper per foot than
LV, if you don't want potential future requests (demands) from the utility to use a HV line on your property for any future development next door, go for small pole pig on your existing pole or a very close pad mount. Do you have distances to potential well site(s) worked out?
