I do IR scans of EVERY substation on our system during peak winter at nights, and peak summer in the afternoons.
I have found several items that could have been extremely costly had it not been discovered through IR analysis.
Bushings with leaking bottom seals in XFs, bam you old bad connections, etc.
even loose bolts.
I have IR some panels and found bad stabs on the panels, loose connections, etc. but as noted earlier, if it’s done on the weekends or when loads are down or non existent, your basically wasting your time.
Camera alone was $23,000
