ItsHot
- A little piece of heaven!
What do you charge to hang a ceiling fan.That is if you still do residential?
I hear that Home Depot charges $150 a fan.
ItsHot said:I hear that Home Depot charges $150 a fan.
robwire said:but i don't have much overhead .
robwire said:Some of you guys probably think that is too low but i don't have much overhead and around here there are 25 differnet electrical contractors looking to cut anybodies throat they can for pennies.They bid out new construction jobs for less money per hour then they could make stocking shelves at walmart.
I know EXACTLY what my overhead is and i recently adjusted it to figure in 5 bucks a gallon of gas just incase and figured on me working five hours a day 40 weeks a year incase it slows down beacuse of the crappy economy( but I am booked solid till the first week of august so..)electricmanscott said:This is a classic misconception. Usually held by someone who doesn't realize just how much overhead they actually have.
robwire said:I know EXACTLY what my overhead is and i recently adjusted it to figure in 5 bucks a gallon of gas just incase and figured on me working five hours a day 40 weeks a year incase it slows down beacuse of the crappy economy( but I am booked solid till the first week of august so..)
robwire said:I was charging 125 for that but I bumped it up to 150 when I saw the home depot price.
Reiker makes a trick adapter thing that makes that unnecessary. I'll see if I can scare one up and take a pic.stickboy1375 said:, drill out the fan box I had roughed in because these fans came with a hook style mounting assembly...
mdshunk said:Reiker makes a trick adapter thing that makes that unnecessary. I'll see if I can scare one up and take a pic.
220/221 said:I used to crank out fans when we were first starting up and I STILL couldn't hang a simple one in under 45 minutes complete with set up and clean up.
I figure an hour each minimum, standard fan, 8' ceiling. If I am just going there to hang one fan I would charge $150 and still not make money.
In the olden days If I charged $150, I would put $145 of it in my pocket and call it a day. I'm starting to miss the olden days.
robwire said:I was charging 275 but now i bumped it up to 300.
Some of you guys probably think that is too low .......
Right. I'm not sure where you buy a 70 dollar attic fan, but even if I did know, I'm not real sure I'd want it.peter d said:Yup, $300 to install an attic fan is definitely too low!
mdshunk said:Right. I'm not sure where you buy a 70 dollar attic fan, but even if I did know, I'm not real sure I'd want it.
peter d said:I know you can buy one that cheap at HD. I've been checking them out over there because I'm looking at putting one in my house...installing the fan is the easy part, but adding the intake ventilation is not.
buckofdurham said:I put two attic fans in the gable vents in my house. I made them both controlled off of one thermostat. This way they will both come on at the same time. I turned one around to blow in and the other one blows out.
They work great like that. Swishhhhh the air flys out of their.
