M4gery
I'm not in business (yet) but I am trying to wrap my head around as much as possible.
I know that most electrical contractors markup material, so there must be a good reason why. However, when I look at it, it seems that it could lead to losing money. So I am trying to figure out if I am looking at this all wrong.
The way I am seeing it, if I install snap switches versus dimmers, I am loosing money by marking material up. If I install normal receptacles versus decora, I just lost money. If I install a Homeline panel versus a QO panel, I just lost money.
If the installation time is the same, why should a contractor loose money when installing a lower cost item?
If you were to move that extra profit from the material markup into the hourly rate, you would make just as much money when installing a $100 versus a $300 fan.
Example: Instead of having an hourly rate of $75 and marking material up X% you would charge retail cost of material and raise your hourly rate to $87/hr (or whatever it would calculate out to). Then you wouldn't make less money when installing 50cent receptacles versus $14 GFCIs.
But since this isn't what is normally done, there must be a fatal flaw in my line of thinking. Any guidance?
