Recently we have a 2400V, 800HP, 3PH, motor (old Louis Allis brand, sleeve bearing, oil ring lubricated, self ventilated) that went thru a rewind. It was a work done to proactively improve the overall insulation quality on the machine. Since then, the motor is making a louder noise. It's hard to quantify how loud but if on the scale of 0-10 (10 being loudest), I'd say the noise level right now is somewhere around 6-7 while the before it was 2-3. The noise is coming from inside the motor and it sounds just like a humming noise in general. We've done all the mechanical/electrical checks that we could do on this motor but found no anomalies. However, when the motor was tested in our local shop, it was okay. Our power supply, load conditions (motor used to drive a high pressure pump) are all the same, so we aren't sure what could be the cause at the moment. I thus wonder if the re-wind could possibily cause some acoustic characteristics to change in the winding? What are other things that we could do to inspect and troubleshoot?
