Re: Counterpoise vs triode
Counterpoise is one of those definitions that should be avoided because it has no single definition. Typically it is a radio term: "Counterpoise, a conductor or system of conductors used as a substitute for earth or ground in antenna systems".
Triode doesn't make much since either. Triode is a electron tube with a anode, cathode, and controlling grid.
"Ground Rings" and "Grids" are the simplest and most effective ground electrodes to connect lightning down conductors too.
In a high rise building, the usual method of lightning protection is just simply the structural steel framework or rebar that the building is made of. It forms a faraday cage surrounding and protecting the contents inside, and discharges lightning into the foundation much like a Ufer ground.
Are you possible referring to a "Triad" or "Tri-Pod"? That is a system of three rods layed in a triangle pattern.
[ March 06, 2004, 08:01 PM: Message edited by: dereckbc ]
