Okay, I get it. You're talking about a rule of thumb to use when laying out circuits.
				Timewatcher384 said:
			Usually I keep and combined total of 10 outlets and lights to a 15 amp circuit.  Am I counting my branch circuits correct.
That's kind of a judgement call on your part. People have their own rules of thumb for this sort of thing. Some guys will catch all bedroom lighting on a circuit, and then deal with the outlets on a seperate circuit to keep appliances like vacuums from dimming the lights.
Mine is basically the same as yours - I keep around ten holes a circuit. But I count cans as being half a hole, since they generally max out at 75W and the ten holes idea is based loosely around the 180W per receptacle idea.
Essentially, there is no code for residential, you can place as many receptacles on a circuit as you'd like. Good design leads you to the ten holes per circuit idea. I found, as I got into bigger houses, that I'd tend to divvy up lighting and receptacles more, to stretch my lighting circuits farther.
Small houses I tended to mix them and just make small zones. Master Bed L&R, Bed 2&3 L&R, General Lighting, Kitchen Lighting, Living Receps, Utility L, and then the required 20A circuits.
