Re: Craftsman Compressor
A heftier cord is NOT going to hurt the compressor. I also wrote that the compressor probably needs a bigger motor.
The UL listing for these units is BOGUS because the compressor is deliberately overloading the motor. You cannot get 2 or 3 or 4 horsepower out of a 15 amp circuit breaker unless the running current is more than 15 amps! You can only do that so much and so often and not trip the breaker. You might as well be using a 2 ounce bird to airlift a 1 pound coconut. (From Monty Python and the Holy Grail.)
This application is probably also overloading the pressure switch or at least loading it enough that it will have short life.
This is not to mention that a 15 amp Federal Pacific circuit melter will often carry 20 or 30 amps indefinitely.
